How to sweep temperature in Keysight ADS
henry kissinger
Member level 2
Member level 2
How Do I sweep the temperature in ADS?
I tried the below but it doesn't work.
That is exactly what is needed to perform a temperature sweep simulation in ADS. Now what/how are you applying the Temp parameter value to your circuit to simulate the temperature dependent performance? The controls you show are only half of the set up.
what do you mean half of the setup? I have temperature sweep from 0C to 400C with step of 100C already, right?
The temperature variable that you are sweeping now has to be applied to a component parameter to perform temperature dependent simulation. You are controlling the temperature variation but what is changing temperature with this? Something in the schematic needs to know it is changing temperature.
