how to sweep corners in cadence ADE?
casual
Junior Member level 2
I am using cadence 514 version i think.
there is a parametric analysis function, but i could not sweep corners like ss, typical ff.
how could I make it beside ocean script?
To run corner sim.:
First, you have to know the defined terms for ur used technology: such as ff, ss, or tt for TSMC.
Then, go to tab Setup -> Model libraries
- Choose any model and set the ff or ss as u want to the option box.
Then run sim. as normally.
Hope that help
I know how to change corners as in model library...
the problem is to sweep corner instead of changing manually
