How to stop a process by running one time
xilinx1001
Member level 3
Member level 3
I wrote a code for triggering the ultrasonic SRF05 sensor
The trigger should be given for 10usec and give a delay of 50msec before next trigger
The process is running with the clock and is running continuously.
code:
process(check_bit,clk)
begin
  if(clk'event and clk = '1') then
  if (check_bit = X"74") then
   if(count2 <= "000000000001001011000"  ) then
    trg2 <= '1';
	   count2 <=count2+"0000000000000000000001" ;
   else
    trg2 <= '0';
	 if (count2 ="1001100010010110100000") then
	 count2<="0000000000000000000000";
	end if;
	end if;
  end if;
end if;
 end process;
How to stop it from triggering continuously
I need to trigger it for only once
Thanks in advance
xilinx1001
after first trigger off 50 ms duration use infinite loop such as while(1); which stop ur process till reset
