How to split a file in UNIX and rejoin it in LINUX ?
cin
Junior Member level 3
Cupertino
how to rejoin split file unix
I've a problem. I would like to split a large size file (>100MB), which is in *.tar format in
UNIX environment, into small size files (< 1.44MB/file). I'm going to transfer these files to Linux platform and then rejoin them. Any suggestion & method to do this ?? The reason I'm doing this is because my workstation don't have cdrom drive. Thanks !
rejoin file split unix
"split" first, then "cat" together under linux
linux how to rejoin split rar
But surely, your workstation have NIC. connect the wire, sup the IP address then use ftp program to move your filesa cross.
RAR sparc verision could do this job well.
You can have this feature after register this software.
