How to speed up simulation in ADS?
SagSag
Full Member level 1
Full Member level 1
speeding ADS
hey,
I'm doing a EM simulation of a PIFA with ADS,
the overall size of the design is 110mmx25mm and the Er used is 2.2.
it take more than 40min to do this (with a 2.2GHz 3GHz RAM),
I know in IE3D it will take less time...
can anyone help me speed up the simulation?
(the mesh is 10 with F=3GHz and no edge mesh)
speeding ADS
if u defined the conductor with thickness , this will make the simulation take longer time
u can adjust the conductor to be sheet , this will speed up the simulation
can u upload ur project , or give me the dimensions , so i can test it
khouly
Reactions: radha
    radha
speeding ADS
why not sonnet? it's the fastest and most accurate EM simulator i know.
Reactions: radha
    radha
Re: speeding ADS
I used metal without thickness and a PEC.
the dimentions are 110x37 mm
thanks
Reactions: radha
    radha
speeding ADS
Which version of ADS are you using?
Are you using finite ground plane ( by default momentum takes infinite GND)?
Reactions: radha
    radha
Re: speeding ADS
Just go to the task manager and in processes tab pick proper and give to it max priority,
also do not tale a lot of points to run
But of course you can do it with other 3D simulators and for sure they will be more faster (like HFSS, CST etc.)
David
Reactions: radha
    radha
can we have finite ground plane specification in ads?
