How to specify object name when using .h and .CPP file
NewbeeAVR
Junior Member level 2
I have LCD class and a object lcd as follows.
class LCD{
public:
}lcd;
How to specify lcd object with two files lcd.h and lcd.cpp
Hello,
I don't see what you mean.
Could you specify :
- The IDE you are using?
- Where are you putting the main code ? is in a main file?
Hello,
Could you specify :
I am using DevC++.
I need to write
lcd.h
class LCD{
void display(char);
lcd.cpp
void LCD :: display(char c){
//my code
Then in main.cpp
#include <iostream>
using namespace std;
int main(){
LCD lcd; // Is any way to not specify hear but anywhere else in lcd.h or lcd.cpp
lcd.display(A);
return 0;
You are creating an instance of the object in your main.cpp. It will work you just need to include the header file in your main.cpp - #include "lcd.h"
Here's how I use my LCD class:
LCD.h:
void SendCharacter(unsigned char character);
LCD.cpp:
void LCDInfo::SendCharacter(unsigned char character)
//My Code here
then in main.cpp:
LCDInfo *objLCD;
objLCD = new LCDInfo(); //I use a pointer
//Call some functions:
objLCD->InitLCD();
objLCD->SendCharacter(chCurrDisplayCharacter);
etc....
