How to Solve the “Naming Error” in the LVS
weiTan
Newbie
Newbie level 1
Dear All
I check the net9 in the layout --------------------(1)
I check the PWM_B,X123/PWM_B in the source--------(2)
(1)(2)is same.
Q:where is the error? Thanks!
You have a number of discrepancies. Start with fixing your port error.
Reactions: weiTan
    weiTan
Hello! Usually if in layout name 1 net and in source name - 2 nets , it means that you shorted PWM_B,X123/PWM_B. Have a look carefully, may be you put extra some vias.
As life huck you mean put some pin (for exapmle "name1") on net PWM_B and pin "name2" on net X123/PWM_B and then LVS will see shorts and it will be easier to find short.
