[SOLVED] how to solder SIM900
aliyesami
Full Member level 6
USA
is there any video or document on how to solder the SIM900 type ICs to pcb? it has strange under body soldering pads that iam confused on how to solder .
thanks
is this something that can be done at home?
are there any ZIF sockets that I can use for SIM900 ?
here is the url to the datasheet
regards
On the top side you can see the contact for solder. I think it is soldered on component side itself like SMD components. You can solder using SMD soldering. You PCD pads should be a little longer such that the bottom pads of SIM900 sit on it and also a portion of the PCB pad is available to solder from the outside.
