VishwanathAmbli
Member level 1
hello,
I want to design inverter with load current 10uA for 50 ohm load.
I have calculated output voltage as vout= Iload * RL and its 50x10u wch gives 0.5mV. substituting this valve in equation in the current equation of nmos and pmos equations i could get a relation between wp/wn and input voltage Vg.i simulated the same in spice but the values didn't match. i have attached here the simulated current value.. its too less than expected.
help me figure out wats wrong.
