goatmxj666
Member level 3
Hello,
I designed digital LDO, and this system contolled by clock.
I want to check stability of this system's loop stability.
first, I did transient simulation when the clock is high and low respectively.
then I fixed all DC voltages for the rest of the system except for the node voltage connected to the loop.
after fix the DC voltages, I simulated the stb simulation with cadence for both environments and it didn't work.
How can I check the stability when the system is clocked?
I would be grateful if you could answer this.
