How to simulate the power out in amplifier using PSpice?
Hablame
Newbie level 2
Newbie level 2
Ampifiers
How can i semulate the power out in a cascaded amplifier unsing the pspice??
Re: Ampifiers
First read user manual. Then build your circuit step by step and simulate it also step by step in order to control your work.
Ampifiers
if u need pspice user manual just download the followingf files:
or visit this site
Re: Ampifiers
y dont u search for plenty of books available here..
and a tutorial:
there may be books other than this available... so search..
/Am
Re: Ampifiers
Here Is Simple Power Calculation for simple Circuit
Download IT
Re: Ampifiers
If you are using a Orcad Capture, after you run the simulation ,go to "PSpice" -> Bias points -> Enable bias display. Then look at the number on top of your power supply.
Ampifiers
Print out I(supply).
Then you can calculate the power.
Re: Ampifiers
Does anyone have any problems using Orchad PSpice student version? I tried to simulate a state-variable filter but the frequency response does not appears to be displaying what the filter suppose to do, which has left me in doubt of this particular software. I have had simular experience with Circuit maker as well, it actually simulate transformer feeding DC!! :crazyeyes:
Ampifiers
hi.
you must draw the simulation of your circuite in pspice and then situate voltage prob in output of circuit.
now analysis this circuite.
you will have output vopltage and current which then calculte power.
Re: Ampifiers
u can get it fro bias supply option.
