How to simulate the osc/VCO ac response?
huanchou
Member level 2
Member level 2
vco ac
Dear all :
I want to simulate the VCO(the delay cell is fully differential type) ac response, but I don't have any idea to do that.
Can I use the method of the fully differential op to do the simulation?
Where can I find the fully differential op simulation method?
pss and pac of spectre
    huanchou
If I want to use the HSPICE to do the simulation, how to setup the circuit and command?
Used feeback theory. You can break the loop and add a testing voltage source and then see the feedback output response for gain and phase. Then check the gain as if bigger than 1 at wanted frequency. If it is, then the circuit is without startup problem.
Yibin.
