how to simulate SNR of DAC in the candence
wany
Member level 2
Member level 2
i have gotten wave of dft . But i don't konw how i can get SNR. thanks your helps
bad_egg3:
Could you please give us more details about it. What's spw and how to set up it?
If you use Spectre to simulate your circuit, you can use the "calculator" to do it.
In the "special fucntion" of the calculator, there is a command of "DFT".
After you choose the command of "DFT", you can easily fill some items, like start time, end time, the point of DFT , and the window of DFT.
Then you can get the SNR.
Yibin.
Hi, how can I do SNR simulation by Hspice ??
BTW, in spectre can I add .vec file into it ??
Thanks
Analog_starter
I heard on said DFT could only see the distortion, SNR is related to noise analysis and should use something related to ac analysis. But I dont know how
nibo_mmx
Yes. you are right. But we can get the quantization noise from the DFT.
Analog_starter
First question: Using .fft command. Also you just get the quantization noise.
Second: I have no idea about it.
Yibin.
[/quote]
You will get many quantization noise but you can't added it up use caculate
How to simulate the SNR of DAC in the HSPICE?
Yes, I also want to know. And for the SNR simulation, what input should add into? 1Mhz ideal digital sine wave codes? And what frequency should use for clock can get the highest SNR? higher clock higher SNR??
Thanks,
Analog_starter
Quote:
Analog_starter
Using .fft in hspice can do fft simulation and get THD. And .vec file can be used too.
But for SNR, i don't kown how to simulate it.
