how to simulate small-signal transconductance (gm) of OTA?
xiaoyanghqu
Newbie level 3
Newbie level 3
china
According to definition of gm (gm=Io/Vin, Vout=0(gnd)),I add a large capacitor(1F) at the output to make it ac ground.Then do ac simulation,and plot the ac Io of the capacitor. But the result i think is not right . What is wrong with the simulation?
Thinks!
Re: how to simulate small-signal transconductance (gm) of OT
Because you want to measure/simulate the output current, the output must not remain open. However, don´t connect a capacitor at the OTA output because it introduces a frequency dependence which belongs not to the device under test (OTA). Instead, use a resistor which produces a maximum voltage in the milli-volts range. This is sufficient to realize the condition Vout ≈0 volts.
LvW,Thank you for your reply! What do you mean that the output must not remain open? Should the OTA be connected to closed loop by a unit feedback? If use a resistor as output load, how to set the DC point of the output transistors? The large capcitor can set the DC point and build the AC gnd, Am I right or wrong?
can you post the simulation setting? Thanks!
When it is open (nothing connected), no current is possible.
No, just loaded by a small resistor.
I was referring to an OTA with split supply voltages and symmetrical behaviour, which means: output current zero for input differential voltage also zero.
Is this the case?
