DoctorWho
Newbie level 3
Dear guys,
I'm now designing an VCO. It's a bit different in that it's periodically turned on/off.
Thus, I have a voltage pulse at a frequency around 1MHz to implement the periodical on/off. Meanwhile, the VCO is oscillating at several GHz. I want to use pss and pnoise to see spectral purity of the VCO when it's on but cannot setup pss simulation correctly.
The simulator seems to consider the frequency of pulsed on/off signal as a fundamental and says that the fundamental tone should be integer multiples of the 'Beat frequency', which I usually set as VCO frequency.
Anyone can help me out?
Thanks in advance.
Thanks in advance.
