How to simulate noise on PSPICE (student version)
mastevano
Newbie level 6
Newbie level 6
how to simulate pspice student
Hello! I would like to simulate noise of a LNA using PSPICE. My criteria to meet is 2.5dB, but PSPICE does not graph in that format. How do I simulate the Noise Figure?
Thanks!
transient in pspice student
In "Analysis Setup", check "AC Sweep", click on the "AC Sweep" button and then check "Noise Enabled". See User's guide for more details.
pspice noise
How to simulation the noise on Hspice?
how to simulate student pspice
.noise
You can read the manual about noise part.
I hope that helps.
how to simulate student version pspice
One more question on the same subject. How to connect any pseudorandom generator to the circuit input to simulate noise in the transient analyzis?
Varuzhan
pspice student
Varuzhan
Generate a random vector in matlab, then export to a file and enter in pspice or hspice as a PWL voltage source.
Bastos
Thank you, but I am looking for more efficient solution. For example, if it possible
in any of simulators, to generate a next pseudorandom value for the each minimal step. In this case, the simulation time will not increase significantly.
Varuzhan
