how to simulate IR RC5 in proteus
mohamed saleh
Member level 3
Member level 3
proteus rc5
i wrote an assembly code for 8051 to run as an ir rc5 decoder
i want to simulate my code in proteus
but how to generate ir rc5 wave form in proteus
and what is the name of the ir receiver in proteus library
i want also an assembly or c sorce code for 8051 to run as calculator with keypad and lcd
" i know that proteus has a sample of calculator on 8051,but it uses HEX file and has not the source code. also it uses an old 8051 chip with external memory, but i have a new chip in which i have not to use extrnal memory,so the proteus hex file wont serve me"
Dear my friend
how to use the pattern generator to send rc5 signal
thanks
Medtronic said:
Dear my friend
thanks
make another circuit design with a micro controller and connect the tx pin to the receiver pin of your micro diagram.Both the ckts should be in same design with different hex code for the controllers
