How to simulate fully differential ota with sc cmfb
newtoanalogdesign
I want to do ac analysis of fully differentila ota having sc cmfb circuit. i know the procedure of doing pss analysis first and then pac.. But i don't have spectre RF licence, so can any one explain how to simulate it using spctre simulator.....
What i did was transient analysis of circuit to find the stable Vcmfb value and then usnig a ideal voltage source i fixed that value, now simulated ac analysis. I want to know is there any other method than this one????
I simulate cmfb with stb analysis of spectre. Add iprobe of analogLib, which aim is connection when dc analysis, is not connection when ac analysis
you can make an ideal cmfb using one vcvs and two resistors.
hi JoannesPaulus,
Can u explain in some more detail. How to connect it and if possible can u show the setup.
you can run trasient analysis until your CMFB is settled. Now run AC analysis and in its option menu click yes "prevoppt". It should do the trick for you.
