melkord
Full Member level 3
Hello,
I have done this simulation previously when I had only the CSA.
Back then, I used noise analysis in Cadence, found the output-referred noise voltage, integrated it, and then divided it with the Cf.
Now I have another block after this CSA and would like to include the noise of this circuit and referred the noise to the input.
Conceptually, it is similar like the method I used previously but now I need to divide the output-referred noise voltage with the transfer function of this block.
Is there a simple way to do this in Cadence?
