Jul 18, 2006 #1 0 020170 Full Member level 4 Joined Jan 31, 2005 Messages 231 Helped 3 Reputation 6 Reaction score 1 Trophy points 1,298 Activity points 2,221 Digital circuit block can be sort out "Static" and "Dynamic." When I simulated Dynamic circuit in Hspice, single circuit is okay. But, in complex blocks, dynamic circuit is not working. No. I am wrong. I don't know dynamic circuit is working or not. Because Hspice is even not working! always, Hspice show me "DC operating point error" or "Iteration limited error" Is there any solution to simulate dynamic circuits in complex block? thanks
Jul 19, 2006 #2 G gigle Junior Member level 1 Joined Feb 9, 2006 Messages 19 Helped 1 Reputation 2 Reaction score 0 Trophy points 1,281 Activity points 1,479 set initial conditions to the floating nodes.
Jul 20, 2006 #3 P pfd001 Advanced Member level 1 Joined Jul 23, 2005 Messages 409 Helped 45 Reputation 90 Reaction score 10 Trophy points 1,298 Activity points 3,214 or put a large resistor at the floating nodes
Jul 20, 2006 #4 Z zenisle Full Member level 2 Joined Sep 11, 2005 Messages 127 Helped 4 Reputation 8 Reaction score 2 Trophy points 1,298 Activity points 1,987 r put a large resistor at the floating nodes
Jul 20, 2006 #5 0 020170 Full Member level 4 Joined Jan 31, 2005 Messages 231 Helped 3 Reputation 6 Reaction score 1 Trophy points 1,298 Activity points 2,221 If I don't know where is floating node? How to find Floating node in my circuit? Or I can't set large resistor value due to a number of Floating nodes How can I solve this problem?
Jul 21, 2006 #6 G gigle Junior Member level 1 Joined Feb 9, 2006 Messages 19 Helped 1 Reputation 2 Reaction score 0 Trophy points 1,281 Activity points 1,479 You should know where the floating node is when you design dynamic circuit. But you are still not interested in the floating nodes, try the option, gshunt=1e-9 or smaller value.
