You may do these simulation..
-Output Voltage vs. Temperature
-Output Voltage vs Process Variations and Mismatch-Monte Carlo Simulation
-PSRR vs Temperature for different Compansation Capacitor if it's available
-Output Noise
-Start-Up vs Temperature with Corners Check<---- Very important
-Latch-Up Test
I simulate the PTAT circuit in the LTspice, not include the startup circuit on the left, I set the parameter L=2u, W=100u, n=8, VDD=3v, R1=R2=100ohmic, I found the current ID1 and ID2 are not the same, ID2 is very very small.
---------- Post added at 16:45 ---------- Previous post was at 16:39 ----------
-Output Noise
-Latch-Up Test
I want to simulate a thermal temperature sensor by using a PTAT circuit to generate the bias current, then connect the current to a ring oscillator to generate the frequency, then count the frequency.
