How to simulate a network drive on Windows XP/2k?
GeneralMadDog
Member level 2
Member level 2
where it smells funny...
windows simulate drive
Hi friends,
I have following problem:
I have a software which expects a license file on a network drive.
On Windows NT I can share a folder of a local drive and reconnect
this folder as a network drive on the same machine. On Windows XP/2k
this method works only if the pc connected to a real network.
If I cut the real network connection, the simulated drive gets also
inaccessable. Is there any tool or trick to simulate a network drive on
these systems?
regards
The General
subst network drive
1. Install VMware Workstation. It adds 2 Vitual Ethernet Adapters to the system, so you will be always connected and you can share own files.
2. Few days ago I configured old 10Mbit Ethernet Adapter (Realter 8019 as I remember) and when I set maually 10Mbps 10baseT mode diode on card ligthts all the time - means always connectd. I don't know how it is seen by WinXP.
I'm always connected to the network so I didn't tested my ideas. But I think you can try.
windows xp simulate mapped network drive
Hi mickeymouse and dsp!
I tried the solution with Microsoft Loopback Adapter: Successful!!!!!
But I will also try the VMware solution.
Many thanks!
The General :) :) :)
subst for network drives
If you're only interested in having a new drive letter, say X:, point to some directory on your PC, try
subst X: c:\my\directory
in a DOS box
D:\NSV>subst /?
Associates a path with a drive letter.
SUBST [drive1: [drive2:]path]
SUBST drive1: /D
drive1: Specifies a virtual drive to which you want to assign a path.
[drive2:]path Specifies a physical drive and path you want to assign to
a virtual drive.
/D Deletes a substituted (virtual) drive.
Type SUBST with no parameters to display a list of current virtual drives.
You'll have to put it in a Run registry key to have it repeat automatically at each start-up.
how to simulate windows xp
in a DOS box
D:\NSV>subst /?
SUBST drive1: /D
a virtual drive.
Hi Vomit ,i don't think it can work , GeneralMadDog need a network drive, but the drive redirected by subst is a local drive.
