How to simplify this series?
Anwesa Roy
Member level 2
Member level 2
I am trying to find z transform of nu(n)
In that I encounter the following problem:
How do I find the simplification of the following series?
z^-1 + 2z^-1 + 3z^-3 + ...... to infinity
Please describe the mathematical steps.
Makes no sense. Specify an unequivocal construction rule.
Infinite series means that it might be described by a simple IIR expression H(z) = a(z)/b(z)
Sorry I am wrong. The series should be
z^-1 + 2z^-2+ 3z^-3 + ...... to infinity
Yes true. Sorry for the mistake
It converges for |z|>1 (root test or ratio test).
So you know for |z|>1
z/(z-1)=1/(1-1/z)=1+1/z+1/z^2+1/z^3+..
and the convergence is uniform (M test or whatever),
so differentiate both sides to obtain
D(z/(z-1))=-1/z^2-2/z^3-3/z^4-..
So your series is
-zD(z/z-1)=z/(z-1)^2
Let's call S(n)=z^-1 + 2z^-2+ 3z^-3 +...+nz^-n
divide now both LHS and RHS by z^-1:
S(n)/z^-1=1 + 2z^-1+ 3z^-2 +...+nz^-n+1
we can note that (2z^-1+ 3z^-2 +...+nz^-n+1) - (z^-1+ z^-2 +...+z^-n+1) = z^-1 + 2z^-2+ 3z^-3 +...+(n-1)z^-n+1
if we call now A = z^-1+ z^-2 +...+z^-n+1 then, summing it to both LHS and RHS:
S(n)/z^-1 A=1 + z^-1+ 2z^-2 +...+(n-1)z^-n+1
but z^-1+ 2z^-2 +...+(n-1)z^-n+1 = S(n-1)
and S(n-1) = S(n) - nz^-n thus:
S(n)/z^-A = 1 - S(n) - nz^-n
S(n)[1/z^-1 +1] = 1 + A -nz^-n from which: S(n) = (1 + A - nz^-n)/(1/z^-1 +1)
We have to find A:
A(k) = z^-1+z^-2+...+z^-k
dividing both sides by z^-1
A(k)/z^-1 = 1 + x^-1+x^-2+...+x^-n
as before x^-1+x^-2+...+x^-n = A(k-1) = A(k) - x^-k
after some passage:
A(k) = (x^-1 - x^-k-1)/(1 - x^-1)
we have to find A(n-1), that is k=n-1:
A=A(n-1) = (x^-1 - x^-n)/(1 - x^-1)
You have now to substitute this result in S(n) then to have the sum to inf just calculate lim(n-->inf) S(n)
even if I paid attention, please check that all my passages are corrrect.
In any case the solution found by elwo06 is faster and more elegant.
So your series is
I mean the convergence of the derived series term by term is uniform
