How to sim the phase noise of VCO with /2 circuit???
gggould
Member level 3
Member level 3
Hi all,
I am designing a 2GHz VCO with /2 circuit.
Now I can use spectre to simulate the phase noise at 2GHz VCO output.
But can anyone tell me what is the correct setting to simulate the phase noise at the /2 circuit, which should be 1GHz ???
How about if I replace the /2 circuit with a *2 circuit??
Thanks very much,
gggould
Is there any difficulties?
Theoretically the SSB phase noise level will DECREASE by 20*logN through a frequency divider. In your case the phase noise performance of your 2 GHz VCO will DECREASE by 20*log2 = 6 dB. But only down to the noise floor level of the /2 device itself. Usually at -140 dBc/Hz or so, consult the data sheet of your /2 divider.
If you instead put a frequency doubler after your VCO, the SSB phase noise level will INCREASE by 20*log2 = 6 dB.
It's very important to understand these mechanisms BEFORE putting it all into the computer...
