How to short 2 ground planes and give excitation in HFSS?
ranj_das
Newbie level 6
Newbie level 6
hfss help
how can i short two ground planes thru , a shorting via can be used, thereafter how do give excitation to the gnd plane
thanx
Re: hfss help
it depends on your application, set a port or a voltage source directly
hfss help
It seems you have not made a face between the two ground ,so maybe you need to setup a lump souce between two grond edge.
hfss help
I think before two ground plane should be intentionally conected.
