[SOLVED] How to shift 4 bits by 4 bits in 16-bit output data?
jianhuachews
Member level 2
Member level 2
Hi guys, how do i go about shift 4 bit by 4 bits in a 16-bit output data?
for example i have "0000000000000000" then i can only send in 4 bits at a time (lets say i send in "1111" the first time and "1010" the second time) so my output should show something like "0000000000000000" => "0000000000001111" => "0000000011111010"
any guidance?
Re: 16-bit shifting vhdl
output_data(15 downto 4) <= output_data(11 downto 0);
output_data(3 downto 0) <= new 4 bit data;
these two statements should be clocked..
Assumind a
my_vector std_logic_vector(15 downto 0)
my_vector<= my_vector(11 downto 0) & "1111"; --shift four bits left and insert the new value in the lower four bits
my_vector<= my_vector(11 downto 0) & "1010";
Alex
Hi vipin. I took your advice and created a testbench too. i checked the waveform and it works the way i want. But xilinx ise gave me this error
ERROR:Xst:827 - "/EDCP6/proj15/jianhua/vhdl/TopLevelKeyTest/Proj_decoder.vhd" line 22: Signal key_data cannot be synthesized, bad synchronous description. The description style you are using to describe a synchronous element (register, memory, etc.) is not supported in the current software release.
Any suggestions?
library IEEE;
use IEEE.STD_LOGIC_1164.all;
use IEEE.STD_LOGIC_UNSIGNED.all;
entity key_decode is
port (
        key_out : out std_logic_vector(15 downto 0);
        enable1 : out std_logic;
        row_indata, column_in : in std_logic_vector(3 downto 0);
        clk1 : in std_logic
end key_decode;
architecture Behavioral of key_decode is
signal key_data: std_logic_vector(3 downto 0);
signal key_out_s: std_logic_vector(15 downto 0);
begin
enable1 <= '0' when row_indata = "1111" else
            '1';
process(clk1)
begin
          if(clk1'event and clk1 ='1') then
				key_out_s(15 downto 4) <= key_out_s(11 downto 0);
            key_out_s(3 downto 0) <= key_data;
           elsif(row_indata="0111" and column_in="0111") then
                key_data<="0001";  -- binary for 1
           elsif(row_indata="0111" and column_in="1011") then
                key_data<="0010"; -- binary for 2
           elsif(row_indata="0111" and column_in="1101") then
                key_data<="0011"; -- binary for 3
           elsif(row_indata="0111" and column_in="1110") then
                key_data<="1111"; -- binary for F
           elsif(row_indata="1011" and column_in="0111") then
                key_data<="0100"; -- binary for 4
           elsif(row_indata="1011" and column_in="1011") then
                key_data<="0101"; -- binary for 5
           elsif(row_indata="1011" and column_in="1101") then
                key_data<="0110"; -- binary for 6
           elsif(row_indata="1011" and column_in="1110") then
                key_data<="1110"; -- binary for E
           elsif(row_indata="1101" and column_in="0111") then
                key_data<="0111"; -- binary for 7
           elsif(row_indata="1101" and column_in="1011") then
                key_data<="1000"; -- binary for 8
           elsif(row_indata="1101" and column_in="1101") then
                key_data<="1001"; -- binary for 9
           elsif(row_indata="1101" and column_in="1110") then
                key_data<="1101"; -- binary for D
           elsif(row_indata="1110" and column_in="0111") then
                key_data<="1010"; -- binary for A
           elsif(row_indata="1110" and column_in="1011") then
                key_data<="0000"; -- binary for 0
           elsif(row_indata="1110" and column_in="1101") then
                key_data<="1011"; -- binary for B
           elsif(row_indata="1110" and column_in="1110") then
                key_data<="1100"; -- binary for C
        end if;
end process;
       key_out <= key_out_s;
end Behavioral;
end if;
use different if statement for clock and row_indata , column_in
dont combine within one "IF" statement
that error is because you are assigning both in positive and negative edge of clock...that is not allowed
use either positive or negative edge...
Try this...
end if;
end if;
