coolstuff07
What is the setup for INL and DNL and hoew to measure
INL and DNL in cadence spectre.
Bye.
Bye.
lladnar23 said:I thought I saw some verilog-a code on Poulton's site to automagically calculate INL/DNL...
erikl said:Use a linear or stair case ramp of about 1bit/sample, and compare the converter's output to its input (reconvert the output by an ideal anti-converter, if necessary). You must take care of the time latency, apparently, (either in time or in voltage/bit domain).
For INL/DNL calculation, use their standard definitions, respectively.
iamxo said:Hi, the histogram testing is also popular, in which the sinusoidal wave input is added. what do you think?
