how to setup and license ic610 in ubutnu
myoss
Newbie level 2
Newbie level 2
Egypt
i'm new to linux and new to ic610 too
i have source of ic610 and i want to setup it and license it too
can anybody help me?
please
thanks in advance for your regards
simply download installscape from cadence download site and run its shell script. To run the shell script, go to the folder where this utility has been downloaded and type at command prompt ./<name of script file>.sh
Installscape is a cadence utility which helps the user to install a tool and its license file (provided you already have the license file).
Regards,
Emma.
i installed it , now i want the command to set environment variables and set library and open access
thanks for regards Emms
can you please share installScape? i can not download it from Cadence.com
thank you
please help installing ic610 on suse 11.3
this is what i get when i tried to execute the setup.sh the ./setup.sh;1 is not being run from the cdrom run ./setup.sh;1 from the mounted cdrom i copied cadence folder to home/cadence/ and everything is already extracted. i don't have...
Software Problems, Hints and Reviews :: 22 Aug 2010 21:31 :: truviet911 :: Replies: 0 :: Views: 30
**broken link removed** | **broken link removed**
