Syukri
Full Member level 5
I've made one R-2R 8-bit DAC, but the ouput is not linear and error..then i've used resistor ladder approach and use transmission gate as switch....the output is ok when there is no switches...but after i put some switches...that the voltage start to drop from and the gnd refference is at 1.xx volt not 0 anaymore...
can i get a solution on how to
settle my switching offset error
Thanks in advance
Syukri
Thanks in advance
Syukri
