how to set page setup in allegro16.3 (pcb)
Tamil Elakiya
Junior Member level 1
when I draw a schematic,
I use: option->schematic page properties to change the page size,there i receive an automatic small box at the corner of the circuit,mentioning the data about the circuit.(Title,date,number,sheet,size,rev)
but,while creating net list am not getting it.
what should i do ,in Oder to receive?
or
should i net list or import?
Thank you.:-o:::-D
hi tamil,
first understand clearly that is title block for schematic and title block will not come in net list file. Net list contain only symbol with net only better study the user guide.
If you want title block in your layout tool than u need draw u own using some 2D tools and import the DXF in to allegro..
or if you are looking for increasing the size of the drawing extents i.e working area then
go to setup --> design Parameters -->Design --> chnage the size in Extents tab..
That is true ,the tittle block cannot not be net listed,but in some of the geber files i saw with the tittle blocks,how come?
Generally people do in 2D tools like auto cad and then from there they will generate DXF which can be imported in to our layout tool..
Reactions: TADE
    TADE
