how to set global include in synplify, like vivado "set global include"
skyworld_cy
Junior Member level 3
I have used `define in several verilog files like
`ifdef FPGA
`else // FPGA
`endif // FPGA
I use an .inc file to enable/disable these defines macros. In vivado I can set this inc file as "set global include" so that every verilog file see these define macros. Is there is a way I can implement the same function in synplify? thanks.
regards
skyworld
"Global include" is a non-standard Verilog extension in Vivado, not provided by other tools (at least I'm not aware of). If you want portable code, use standard Verilog language means.
LaTeX Commands Quick-Menu:
