challenger
Junior Member level 3
- Joined
- Feb 2, 2003
- Messages
- 27
- Helped
- 1
- Reputation
- 2
- Reaction score
- 0
- Trophy points
- 1,281
- Activity points
- 324
pic18f452 fuses
I have just switched from a pic16f877a to a Pic18f452 and I need some help in setting the the 7 config boxes, for fuse settings within IC-PROG.
I need to program the 18f452part with these fuse settings:
OSC set to -- XT
Write Enable -- ON
WDT -- ON
PWRT -- ON
LVP -- OFF
ALL CODE PROTECTS set to OFF
DEBUG -- OFF
Could some one please tell me what equivalent 4 digit hex values I should use to obtain the above settings.
Also : is there anything else that I should be aware of, for successfully programing a 18f452 IC?
Rgds
Challenger
OSC set to -- XT
Write Enable -- ON
WDT -- ON
PWRT -- ON
LVP -- OFF
DEBUG -- OFF
Rgds
Challenger
