cjupiter
Member level 2
common mode input
In a folded cascode opamp there is a tail current at the differential pair (assuming an NMOS differential pair.). I have simmulated this tail current using a current source that is available in spice. According to my frequency response everything is fine, however....
My problem is that when I offset my input voltage to the desired common mode level, (in my case around 1.3V) my output voltage seems to sink below Vss which is ground. How do i set my opamp to operate about the same input common mode level.
I should also mention that the voltage at the differential input tail is negative. Could this be the problem?
