How to set a decimal points in pads2007
srinims
Newbie level 5
Newbie level 5
bangalore
Hello,
I am using pads 2007 for layout. I have a problem in measuring(dimension). While measuring In metric only one decimal point is comming . I need minimum 3 decimal poins .. Please help me how to set a decima points.
Regards,
Srinivas
How are you measuring?
Just try changing the grid you are working with
Then also i m not able to get the decimal poins...only one decimal point is comming..
Regards,
Srinivas
Hi Srini,
You can set the decimal places as follows.
Go to Tools --> Options --> Dimensioning --> Settings --> select Text --> in that set the Linear precision value as 3 --> ok
Now you will get 3 decimal places.
Regards,
Ahar.
    srinims
