how to send the data to usb to RS-232 converter
vmaxusb
Junior Member level 3
usb to com converter vc++
Hello,
I am doing a project on USB interfacing.i have available plug and play USB to RS-232 converter.i have installed this device successfully and the device manager is showing the prolific USB to serial converter.i want to send the data to this USB to RS-232 converter.i am not getting any virtual address in device manager for this port.i want to send the data to this port in turboC/C++/VC++.can any one tell me how is it possible?
Regards,
vmaxusb.
IMHO, the USB to RS232 converter will be visible as a COMM x port. You will have to scan the available ports and select the correct one.
Cheers
Ravi
Hello,
it is visible as a comm5 port.but i am not getting any address for this.because i need to program this porti.e i want to send some data to USB to serial converter in C/C++ or any other assembly language.can you help me regarding this?
All the other ports comm1 to coo4 are in use.
With Thanks And Regards,
vmaxusb
In this I won't be able to help you since I do not know PC programming.
Cheers
Ravi
It will be Com5 & u have to configure ur port as ur are configuring other serial ports
like baud rate , start bit, stop bit, data bytes, etc.
