How to send system time to parallel port using Assembly?
ehsanelahimirza
Full Member level 6
Full Member level 6
hi all
plz tell me how to send system time to parallel port by using assembly
time is 00:00 to 23:59 which needs 11 bits but data pins r only 8
then how to use control pins
plz help me. i m confused
n thaks in advance
Re: assembly help needed
The base address, usually called the Data Port or Data Register is simply used for outputting data on the Parallel Port's data lines (Pins 2-9).
The Control Port (base address + 2) was intended as a write only port. When a printer is attached to the Parallel Port, four "controls" are used. These are Strobe, Auto Linefeed, Initialize and Select Printer, all of which are inverted except Initialize.
You can use Control pin as you use Data Port with different post address
For more information, please took a look at **broken link removed**
