mpch_elec
Member level 1
- Joined
- Jul 22, 2009
- Messages
- 33
- Helped
- 3
- Reputation
- 6
- Reaction score
- 3
- Trophy points
- 1,288
- Location
- Tehran,Iran
- Activity points
- 1,505
GPRS
How to send Data with GPRS...
mpch_elec said:How to send Data with GPRS...
>> AT+CGATT=1 - Attach to GPRS Service
<< OK
>> AT+CGDCONT=1,"IP","wap.cingular" - Define PDP Context (cid, PDP type, APN)
<< OK
>> AT+CDNSCFG="208.67.222.222","208.67.220.220" - Configure Domain Name Server (primary DNS, secondary DNS)
<< OK
>> AT+CSTT="wap.cingular","wap(at)cingulargprs.com","cingular1" - Start Task & set APN, User ID, and password
<< OK
>> AT+CIICR - Bring up wireless connection with GPRS - THIS MAY TAKE A WHILE
<< OK
>> AT+CIFSR - Get Local IP address
<< 10.190.245.172 - returns IP address assigned to your module
<< OK
>> AT+CIPSTATUS - Get Connection Status
<< OK
<< STATE: IP STATUS - returns status of connection, needs to be 'IP STATUS' before you can connect to a server
>> AT+CIPHEAD=1 - Tells module to add an 'IP Header' to receive data
<< OK
>> AT+CDNSORIP=1 - Indicates whether connection request will be IP address (0), or domain name (1)
<< OK
>> AT+CIPSTART="TCP","www.google.com","80" - Start up TCP connection (mode, IP address/name, port)
<< OK
<< CONNECT OK - Indicates you've connected to the server - IT MAKE TAKE A WHILE FOR THIS TO BE RETURNED
>> AT+CIPSEND - Issue Send Command
<< > - wait for module to return'>' to indicate it's ready to receive data
>> GET / HTTP/1.1 - Send data - this example is an HTTP request for the default page
>> Host: [url]www.google.com[/url]
>> Connection: Keep-Alive
>> Accept: */*
>> Accept-Language: en-us
<< data from server returned - Server will return data here
