How to send data from output of adc to computer using VB?
ram indra
data from adc to pc
would u please tell me how to access tha data from output of adc to computer using visual basic.
i am plannig to use parallel port.
Re: data from adc to pc
h**p://support.microsoft.com/default.aspx?scid=kb;en-us;823179&Product=vb6
Use MSCOMM component
Edson
Use Data Bits to receive
Assalamo Allykum !
If you want to receive the data from the ADC to PC then use the Data Pins of Parallel Port.
I think you are using 8-bit ADC. If you are using 8-bit ADC then use the Data Pins to receive the data.
But for receiving the data first you have to use the bidirectional property of Parallel Port.
First Makee the ParallelPort BiDirectional in the BIOS.
Make HIGH the 5th Bit of Control(Baseaddress + 2) to receive the data,,,,, and make LOW the 5th Bit of Control(Base Address + 2) to transmit the data.
Before receiving the data make all the oins of the data pina HIGH . (It is important)
Wish you good luck. :!:
If you have any problem then you are free to ask. :D
Keep remember me in your prayers.
Zeeshan Shareef
Industrial Electronics Engineer
IIEE, PCSIR, Karachi
