Aigneryu
Member level 3
shift out parallel port
I've got a chip to test but its control interface is mainly composed shift registers. And I have to access the ports in order to input the specific bit streams.
First problem is that the signal level is not proper for direct input to my chip. And the second problem is that I don't know how to control these ports. In fact, I need a serial control bit stream aligned with a clock for shift registers.
Do anybody know where can I find some useful material for programming?? An example or reference books.
