how to select Output Capacitor in Booster?
parachutes30
Junior Member level 1
This is from Ti TPS40210 datasheet。
but I couldn't understand there is a "8" before Iout x Ton / Vripple。
I think it's possibly the 8Vin min. they use for the whole design procedure, in table 1 on page 25.
That "8" is dimensionless.. so it is not a voltage.
You can ask yourself the same question for the ESR: why 7/8 ?
Same for Cin: why 4 multiplies Vin ripple ?
Probably are some values for safety margins Texas Instruments arrived to in their years of experience designing stuff.
Reactions: d123
    d123
Please my friend, do not use such formulae for capacitor ripple in output of boost...use the formula as follows.........ac(rms) ripple = sqrt(irms^2 - idc^2)
where
irms = the rms current coming out of the boost diode
idc = the dc output current of the boost.
....the above two things are easily found frm standard trapezoid wave eqautions.....
i post them here, the trapezoid equations are in there
(but also here
www.oocities.org/capecanaveral/lab/9643/rms.htm
if doing regular hardswitched smps regularly , you must please use trapezoid equations...it takes too long too keep doing the integration every time.
  • Core Mathematics and Equations for SMPS design.doc
Here is the eqaution for IRMS of a trapezoid current waveform
IRMS = SQRT[D * (I1^2 + I1.I2 + I2^2)/3]
where D = duty
I1 = the only thing it can be in that equation
I2 = ditto
This is one of the most key waveforms in hard switched SMPS as you know.
And a triagle wave is just a trapezoid with one side zero
A square wave is just a trapezoid with 2 sides equal.
...so its good for tri's and squares too.
NOT worth doing the integration every time...just see the equation.
OK!
I can understand that setting 8 mulitpler cap is to allow for a load transient.
So do you agree if we don't need to consider load transient, can I omit this "8"?
After carefully reading this document form TI, I think a bulk electrolytic cap is only for transients and ceramics is very one that for reducing the ripple.
Like the TPS40210 picture, TI designer seems always use a parallel combination of electroytic and ceramic.
https://www.ti.com/lit/an/slta055/slta055.pdf
Reactions: CataM
    CataM
