Eight
Member level 2
Hello.
I'm designing a custom lighting control circuit and I want to know how to protect its outputs.
Suppose you have a DC load rated 1A@32VDC (light bulb or a LED+resistor) that is driven by a low-side N-channel mosfet. The mosfet can drive the load via a PWM waveform or simply act as an on/off switch. This load is located off-board and connected by a wire. Now suppose something goes wrong and the load shorts out (designated by the SW1 switch on the attached image). I would like to protect the mosfet with a fuse, but unfortunately I'm having trouble understanding how fuses work (or rather how to select them for the given application).
How does one choose a fuse so that it melts before the mosfet does?
I did some reading on fuses and learned they are categorized (besides current and voltage) by their I²t rating, which supposedly represents the maximum energy before melting. Fuses apparently take longer to melt than some other semiconductors. So I'm wondering what's the criteria here? Can I get away by selecting a fuse only by its current rating so that the mosfet has a larger continuous drain current rating than the fuse or do I have to take the I²t value into account? If so, how does one compare a I²t rating of a fuse against a mosfet?
The PSU is rated 32VDC@10A (10A because it's powering some other things besides the DC load). The lowest absolute maximum rating of the circuit is 50V.
Thanks in advance.
Thanks in advance.
