How to see the waveform of Spectre with other wave tools?
sunwiss
Junior Member level 3
spectre waveform fsdb
I have done pss, pac, sweeppss etc.
what tools can be used to see the results beside Cadence Spectre?
spectre fsdb
We had been using nWave as a waveform viewer. It is a fast viewer and works well
spectre waveform viewer
The format of spectre output is ".pss", but nWave only read .fsdb files.
What can I do then?
spectre waveform viewers
If you run spectre from a shell with command line options there is an option to set output format. I remember it is spice native but have not tried it in the past.
