How to see the far fields in EMDS?
TerryADS
Full Member level 2
Full Member level 2
USA
Hi friends,
I want to design antenna using ADS EMDS.and my antenna includes capcitors,diode and copper.How can i see the far field?whether i can use co-simulation function?
Thanks,
You can use the co-simulation. once you satisfactory using the complete simulation re-run the structure for far-field results in EMDS.
    TerryADS
Infect you don’t need to do perform co-simulation for FAR Field calculation in EMDS.
1. Just simulate your project in emds
2. Select EMDS>Post Processing>Compute Far Field
3. Now select EMDS>Post Processing>Visualization
4. In visualization turn on "Far Field” tab
    TerryADS
