How to see EBG refection phase results?
bongao
Newbie level 5
Newbie level 5
I have simulated a mushroom like EBG structure in HFSS V9.2. I illuminated the surface by a incident wave. But I don't know how I can see the reflection phase results. Does anyone here give me some suggestion?
Many, many thanks
Gao
Re: EBG refection phase
As far as I know, HFSS10 is computing the reflection coefficient based on Pointing vector (power) definition and as such it gives only the magnitude of the reflection but it doesn't compute its phase. To compute the phase and magnitude, you would probably need to write your own script (in VBScript) and execute it using HFSS.
EBG refection phase
Thanks, ^_^
I remember you can download a powerpoint in ansoft's website about the reflection phase of the EBG surface. You can extract the phase information by using "field calculator". Hopefully it will help.
