how to scan .class files in java
goosecool
Junior Member level 3
I have a .jar file which when "unjar'ed" gave me a bunch of class files. How can I find which of those class files had a main method?
Thanks.
When you extract the JAR file, you get to see the "META-INF" folder inside which you have the manifest file. Inside the manifest file, there is a 'Main-class' property which tells you the entry point ( the class that has the main method). It might look something like this...
Manifest-Version: 1.0
Main-Class: archsoft.testcases.VideoPlayer
hope this helps!
Good day
Ji
Use java decompiler called jad
then use
jad -sjava *.class
tnx
    goosecool
yup ... java decompiler helped .. thanks
