how to run wgl pattern generate by DFT tools,
stormwolf
Full Member level 1
wgl pattern
After ATPG , DFT tools will generate some format pattern , and we generate WGL format pattern , before we just use the testbench generat by ATPG tools ,
now we heard someone use WGL or some other format pattern to run , and i
want to know which tools can do this or how to deal with it . Thanks.
WGL files are normally used for the tester (ATE). Most vector translation tools (TSSI, VTRAN) will take WGL as input, and can translate to whatever ATE format you use.
John
DFT Digest
Use vtran to convert your wgl files to 1's and 0's.
Vtran also can generate the verilog testbench to run the test
Setup frequency and input output timings in the vtran setup.
Running the verilog test bench generated by vtran will give a pass/fail message at every cycle of the stimulus.
Naveen
Visit http://vlsiforum.com
hi ,
If,You can load the design and wgl file into the tool and every tool will genrate the verilog files from the wgl file if you follow this procedure.
regards,
ramesh.s
