lhlbluesky
Banned
calibre PEX,pls
when i extracted PEX netlist (for ex: circuit1.pex.netlist)using calibre, how to run simulation with the PEX netlist in spectre (ic5141)? what is the procedure?
In input.scs, i delete the netlist part (with no parasitic parameters), and include the PEX netlist (for ex: include ./circuit1.pex.netlist), then run the simulation (run & netlist and run). but the result is the same, there is no difference. why?
besides, if i complete the post-simulation, how to observe the results (current or voltage waveform), just the same as before, select node and print esc button? or are there any other methods?
and, if use 'spectre input.scs' in terminal, then how to observe the results (current or voltage waveform), is results brower ok? or any other ways?
pls help me, and tell me how to do post-simulation in calibre step by step, pls, thanks all.
