How to run an application in my program?
NTFS
Member level 3
Member level 3
Hi all
I am writing a program with VC++ .NET ( in windows form application in visual studio)
now I want to know how can I run a PDF file ( or an .exe file ) in my program?
Thanks.
look into the system() call and execv() and execl() calls. I know that is what the normal G++ and C++ uses
hi
you can use system fuction for running any command compatible to command prompt so by giving the path of file as argument in the system function u can make all the files which are recognised by os to start.
cheers
bye
I found one line code to do that.
I can do it because of your help.
System::Diagnostics::process::Start( "myProg.pdf" );
