davidwuf
Junior Member level 1
Hello, Everyone,
For the two connected neighbour pins (same net) of an IC, how should we route the wire between the two pins?
One option is just to draw a line between pins, but it would be causing a problem : there is solder bridge seated on the pins (at the condition of no solder mask dams between the pins)
The other option is to draw a line that does not occupy the spacing between the pins, in other way of routing them.
Which is correct?
Please find the attached pictures you will get what I am talking about.
Best Regards,
David
Which is correct?
Best Regards,
David
