Sep 23, 2011 #1 L lahrach Full Member level 3 Joined Feb 6, 2009 Messages 170 Helped 0 Reputation 0 Reaction score 0 Trophy points 1,296 Activity points 2,285 Hi all, When I want to add a XPS module to ISE 11.5 ; i GOT THIS ERROR could not create XPS module, running C:/Xilinx/11.1/EDK/bin/nt/xps.exe failed. REGARDS
Sep 24, 2011 #2 sanju_ Full Member level 3 Joined Mar 31, 2011 Messages 150 Helped 35 Reputation 70 Reaction score 33 Trophy points 1,318 Location BANGALORE Activity points 1,997 Hi, When did you get error?(after or before adding) Are you able to create BSB??
Sep 24, 2011 #3 L lahrach Full Member level 3 Joined Feb 6, 2009 Messages 170 Helped 0 Reputation 0 Reaction score 0 Trophy points 1,296 Activity points 2,285 Hi sanju_ Just after add source=>embedded processor => Error This is the first time when I get thit error regards
Sep 24, 2011 #4 sanju_ Full Member level 3 Joined Mar 31, 2011 Messages 150 Helped 35 Reputation 70 Reaction score 33 Trophy points 1,318 Location BANGALORE Activity points 1,997 Hi, Add source? or New source?... if add source make sure that no space in location of your project (Ex: C:\Documents and Settings\Files ) Creating a project using the Base System Builder XPS virtex-5 examples Last edited: Sep 24, 2011
Sep 24, 2011 #5 L lahrach Full Member level 3 Joined Feb 6, 2009 Messages 170 Helped 0 Reputation 0 Reaction score 0 Trophy points 1,296 Activity points 2,285 Thank you sanju my project was in an external hard disk thanks
